Введение
This fix is safe and only requires a screwdriver.
Выберете то, что вам нужно
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the front panel by lifting it away from the camera's body.
Remove two 6.5 mm black screws from the panel.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Еще один человек закончил это руководство.
