Введение
The three stacked rings in the lens mount ring can be safely and easily removed.
Выберете то, что вам нужно
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the front panel by lifting it away from the camera's body.
Еще один человек закончил это руководство.
Один комментарий
Very handy. One addition though - the silver button lever is on the wrong side - it is not facing the mirror box but the plastic lens release button. Plus, you are missing the fact that there is a spring underneatch the silver leaver which keeps the mount pin coming back up.
