Введение
The top panel can be safely separated from the camera body, but it will remain attached by several wires and a ribbon cable. Separating the top panel allows access to several important components.
Выберете то, что вам нужно
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Еще один человек закончил это руководство.
