Введение
This guide will help you step by step to reach and replace the inner eyepiece of canon EOS 30.
Инструменты
Запчасти
Никакие детали не требуются.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Remove the two 9.5 mm black screws that attach the inner eyepiece to the camera's body and remove the eyepiece.
3 участников успешно повторили данное руководство.
