Введение
The bottom panel can be easily removed, and allows access for replacement on other parts of the camera.
Выберете то, что вам нужно
Using your finger, carefully pry open the side panel from the top of camera.
Pull panel downwards to remove.
Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
Remove five black 4.8mm Phillips #1 screws.
Simply remove the bottom panel by prying it off with your finger.
Be wary of a loose piece of foam attached to the bottom panel.
Еще один человек закончил это руководство.
Один комментарий
muy buena la explicacion de como desmontar la maquina. Te has gadano los 30 puntos
