Введение
Use this guide to replace your camera's command dial.
Выберете то, что вам нужно
Using your finger, carefully pry open the side panel from the top of camera.
Pull panel downwards to remove.
Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
Remove five black 4.8mm Phillips #1 screws.
Simply remove the bottom panel by prying it off with your finger.
Be wary of a loose piece of foam attached to the bottom panel.
On the top panel, remove the silver 3.8mm Phillips #1 screw right below the command dial.
