Canon EOS 40D Date and Time Battery Replacement
Выберете то, что вам нужно
  1. Canon EOS 40D Date and Time Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Date and Time Battery Replacement: шаг 2, изображение 1 из 1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Date and Time Battery Replacement: шаг 3, изображение 1 из 1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: шаг 4, изображение 1 из 3 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: шаг 4, изображение 2 из 3 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: шаг 4, изображение 3 из 3
    • Remove the date and time battery holder by sliding it out of the slot.
  5. Canon EOS 40D Date and Time Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the date and time battery from the battery holder.
Заключение
10 человек успешно провели ремонт по этому руководству.
Doug Kruse
Участник с: 09/03/15
788 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 12-3, Blackwell Fall 2015 Участник USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 членов
Автор 16 руководств
6 Комментарии к руководству
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
David Drinkwater - Ответить
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
Stephen Spratley - Ответить
This was so helpful, thank you! Also if you are in a jam and do not have a CR2016, you can use a CR2032 directly without using the normal battery tray.
paniak - Ответить
Great help! Accurate, easy to follow directions
Jack Applegate - Ответить
Excellent. Just what I needed, to bring life back to the dead.
pvlewisnz - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 20
За последние 30 дней: 139
За всё время: 16,880
