Введение
An Error 99 is an non specific error which means that camera doesn't know or have a code for the problem. In my case the shutter assembly needed replacing. This was a fairly involved process for a beginner such as myself.
This is not a comprehensive guide but should be used in conjunction with the Canon Service Manual and youtube videos. I hope that some of the pictures I took along the way might help you identify or remember how each step works.
Выберете то, что вам нужно
Get the Canon 40D Service Repair Manual
Have a clean and organized workspace. I labelled plastic trays by step number and put all items for each step in a separate tray.
Watch a couple Youtube videos on this process
take off rear
connectors disconnect by flipping black/brown tab up and sliding plastic tab out.
remove metal back
remove and replace shutter assembly, transfering components that aren't on the new one
6 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
how do you replace the bridge (male portion on camera) other than putting the card in a card reader
how to replace the focus lock beeper
