Canon EOS 5D Mark II Clock Battery Replacement
Выберете то, что вам нужно
  1. Canon EOS 5D Mark II Clock Battery Replacement, Clock Battery: шаг 1, изображение 1 из 1
    • Lift the rubber flap covering the input/output jacks.
  2. Canon EOS 5D Mark II Clock Battery Replacement: шаг 2, изображение 1 из 1
    • Using a Phillips #000, remove the single 3.4 mm screw.
  3. Canon EOS 5D Mark II Clock Battery Replacement: шаг 3, изображение 1 из 1
    • This step will permanently erase all user settings.
    • The memory battery can now be easily slid out of place.
    • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
Заключение
16 человек успешно провели ремонт по этому руководству.
Mike Seed
Участник с: 09/22/14
3 115 Репутация
Автор 8 руководств
Команда
USF Tampa, Team 1-6, Hickman Fall 2014 Участник USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 членов
Автор 17 руководств
4 Комментарии к руководству
This Battery for Clock only? or CMos and Personal setting to?
there has to be something to retain all these settings once the main battery pack goes dead and or is removed from the camera?
My User 1 Pictures styles wont Save? it'll save but once i turn off My Canon Eos 5D Mark II and then back on again, my Color /Contrast/Sharpness are all Dead Center/= back to Default AGAIN? :/
Any Help here?
THANK YOU,
Greg - Ответить
I did not write the original post, but I believe once you remove this battery ALL custom changes and time will be gone. You will have to re-create them. Besides the rechargeable battery, the only one keeping track of some settings is this one.
CL
Carlos Lijeron - Ответить
Will doing this reset the shutter count in the camera? Like when you go to an external program to see how many shutter actuations there have been over the lifetime of the camera, will that number be erased?
Tom Fewchuk - Ответить
No, because some faulty behavior i removed my clock battery from my 5D MK2, but the shutter count is still the same, it would be to easy to hack a camera to be sold on a good price. :)
Vass János Szilárd -
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 28
За последние 30 дней: 157
За всё время: 28,063
