Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Using a hairdryer or heat gun, heat up the lens for removal. This should not take longer than 30 seconds.
Now using a suction cup, I used a suction from a sponge,apply the suction cup to the plastic lens. Now just pull the lens away from the camera to remove the old lens. This may require a small amount of force.
If it does not want to budge, try reheating.
At this step you may need to reheat the bottom of the lens if it does not come fully off.
You may need to cover the cracked area of the screen with a screen protector, or just regular packing tape. After removal, clean off remaining adhesive.
After removal, make sure to remove all pieces of the old lens. Checking for fragments of plastic, and dust on the LCD.
Now grab your new adhesive tape from your new lens, and apply to the camera side only.
Once lined up apply pressure around the sticker until the tape is firmly in place
Remove the protective film from the screen and apply to your camera. Make sure everything is lined up, and placed properly.
You now have a camera that looks like it just came out of the box!
12 участников успешно повторили данное руководство.
8 Комментариев
Thank you for making this guide, it helped me fix my camera!
Randy
Um, that's a window, not a lens.
Sarcasm I hope?
Great guide, thank you for posting it. Fixed my 5DM2 in under 5 minutes!
But where do i buy the windowglas?
