Canon EOS 60D Rubber grips Replacement
Выберете то, что вам нужно
  1. Canon EOS 60D Rubber grips Replacement, Rubber grips: шаг 1, изображение 1 из 1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
Заключение
Double stick tape, or rubber cement (placed carefully) should work well. Studio-mount (sheets of double-stick tape) cut to size should also work.
10 участников успешно повторили данное руководство.
Eric D
Участник с: 11/13/12
1 284 Репутация
Автор 5 руководств
Один комментарий
Where can we get replacement grips?
Luke Lin - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 18
За всё время: 11,898
