Введение
The grips for the 60D come off easy, they just peel off. For many 60D owners, Canon already helped you by choosing a poor / defective adhesive for the first few batches of cameras shipped.
Выберете то, что вам нужно
Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
Repeat for the other two grips
Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
Optionally throw the balled up adhesive at people pretending its a booger :)
Double stick tape, or rubber cement (placed carefully) should work well. Studio-mount (sheets of double-stick tape) cut to size should also work.
10 участников успешно повторили данное руководство.
