Введение
In this guide, you will learn how to replace the main board in the EFS 18-135mm lens. The main board is crucial to the correct operation of the lens, passing focus commands from the camera to the lens.
Выберете то, что вам нужно
First, detach the lens by pressing and holding the release button highlighted in the picture.
Next, grab the lens and rotate it counter-clockwise when looking at the camera.
Finally, when the camera stops rotating, pull the lens away from the camera.
Remove the four 5.5-mm Phillips #000 screws for the lens mount ring (silver ring).
Remove the two 4-mm Phillips #000 screws mounting the main board connector.
Using a spudger, pull the connector loose from the barrel switch ring assembly.
Set barrel switch ring assembly to the side.
Remove the two 4-mm Phillips #000 main board mounting screws.
Remove the main board from the lens with your hand.
The main board is now successfully removed from the lens.
Еще один человек закончил это руководство.
