Введение
This guide shows you how to install the front panel of your camera.
Выберете то, что вам нужно
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Using the flat end of a spudger, loosen the connection between the front panel and the device.
Remove the front panel using your hands.
Еще один человек закончил это руководство.
