Введение
This guide shows you how to install a new lens connector.
Выберете то, что вам нужно
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Using the flat end of a spudger, loosen the connection between the front panel and the device.
Remove the front panel using your hands.
Using a Phillips #00 screwdriver, remove the 5 indicated screws
Five 6.2 mm Phillips screws
2 участников успешно повторили данное руководство.
