Введение
Replacing the motherboard is a last resort for correcting water damage to the camera. This guide will help you remove it step-by-step.
Выберете то, что вам нужно
Hook your finger onto the compartment door latch.
Open the battery compartment door.
Peel away the rubber grip on the left side of the camera with your fingers.
Disconnect the orange cable at the bottom of the camera by gently pinching with your fingers.
Detach the blue cable by sliding the pointed end of a spudger between the motherboard and the silver prongs connected to the cable.
Locate the cable on the top left corner of the motherboard.
Pinch the round, white connector with tweezers and gently remove the cable.
With tweezers, pinch the ends of the remaining orange ribbon cables, and gently pull these ends off of the motherboard.
19 участников успешно повторили данное руководство.
7 Комментариев
There was one huge step left out. On the T3i there is a fiber optic cable connection on the underside, top right hand side of the motherboard. If you don't reconnect this before reassembly your camera won't work. It is difficult to make sure both this cable and the adjacent white round-wire cable are connected before putting the motherboard back in place.
How do you connect it?
I concur with Albert Einstein. It was very difficult. This should be mentioned int the steps, not reserved for the comments!
Yes, 15 step. to make it easier to connect the optical cable and the second rear cable is better to remove the top cover
