Canon EOS Rebel T4i Battery Replacement
  1. Canon EOS Rebel T4i Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Battery Replacement: шаг 2, изображение 1 из 1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
Заключение
3 участников успешно повторили данное руководство.
Nimisha Patel
Участник с: 04/14/14
164 Репутация
1 руководство автора
Команда
Cal Poly, Team 12-33, Maness Spring 2014 Участник Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 членов
Автор 14 руководств
Один комментарий
Black tab on cover of the battery is constantly disengaging either when I am using or in my camera bag therefore battery runs down. Seems like a design fault to me. Anyone else having this problem ? Have been using sticky tape to keep it in place but still have a problem with the cover moving around and disengaging battery. Replacing with a new flimsy one from Canon at minimum cost of £40 is not on - knowing it will only happen again. I have given author 30 points for covering the topic but sadly have no idea how to solve this problem
esther allwood - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 34
За всё время: 3,078
