Введение
Using these instructions, we'll make it easy and simple for you to replace the LCD in your Canon camera.
Выберете то, что вам нужно
Locate the battery cover at the bottom of the camera.
Pull down on the black tab to open the cover.
Push the grey tab on the right side of the battery.
Remove the battery from the slot.
Remove the six screws on the housing of the LCD.
Four 3.1mm Phillips screws on the side with the hinge.
Two 2.7mm Phillips screws
6 участников успешно повторили данное руководство.
