Canon EOS Rebel T5 Back Panel Removal
Выберете то, что вам нужно
  1. Canon EOS Rebel T5 Back Panel Removal, Battery: шаг 1, изображение 1 из 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Back Panel Removal: шаг 2, изображение 1 из 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Back Panel Removal, Back Panel: шаг 3, изображение 1 из 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Back Panel Removal: шаг 4, изображение 1 из 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Back Panel Removal: шаг 5, изображение 1 из 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  6. Canon EOS Rebel T5 Back Panel Removal: шаг 6, изображение 1 из 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  7. Canon EOS Rebel T5 Back Panel Removal: шаг 7, изображение 1 из 3 Canon EOS Rebel T5 Back Panel Removal: шаг 7, изображение 2 из 3 Canon EOS Rebel T5 Back Panel Removal: шаг 7, изображение 3 из 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
Заключение
4 участников успешно повторили данное руководство.
Johnyp
Участник с: 08/26/15
254 Репутация
1 руководство автора
Команда
USF Tampa, Team 16-4, Wollert Fall 2015 Участник USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 3,379
