Введение
If the display on your camera has stopped working or is cracked and otherwise not functional, it will need to be replaced. This guide will show you how.
Запчасти
No parts specified.
  1. Lay the camera on its back so that the card/battery door is facing you.
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Lift the now free card/battery door to reveal the battery compartment.
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Turn the camera so that the back is facing to your right.
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  4. Remove the rubber piece.
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Turn your camera so that the bottom is facing you.
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  6. Now turn the camera so that the front is facing towards your right.
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  7. Now that all of the exterior screws have been removed, grip the camera firmly on both sides. Gently pry the back panel from the main body of the camera. There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
  8. Remove the four silver 4mm Phillips #000 screws connecting the LCD screen to the back of the camera. Be sure to lift the ribbon cable to remove the remaining hidden black 4mm Phillips #000 screw.
    • Remove the four silver 4mm Phillips #000 screws connecting the LCD screen to the back of the camera.
    • Be sure to lift the ribbon cable to remove the remaining hidden black 4mm Phillips #000 screw.
  9. The LCD screen can now be lifted from the right side to be replaced.
    • The LCD screen can now be lifted from the right side to be replaced.
Заключение
3 участников успешно повторили данное руководство.
Austin Tucker
Участник с: 27.08.2015
925 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 16-4, Wollert Fall 2015 Member of USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 членов
Автор 7 руководств
This guide is NOT COMPLETE. THere are several missing screws that need to be removed.
2 from the viewfinder,
and 2 from the IO ports....
Do not follow this and force the back open or you will need more repair!
11romej - Ответить
Hi, I followed every step and replaced the LCD screen but when turned on the camera, I only got a yellow horizontal line. Do you know what could have gone wrong? Thank you.
Griselda Garcia - Ответить
Hi, excellent guide but I’ve a problem.
I’m need to buy a lcd display. Do you know where can I buy ? Can you recommend me one store to buy it?
Nicolás Morales - Ответить
@nickmorales I found the lcd display as well as the connected controller card ar eBay.
Tom Kane
Tom Kane - Ответить
I had problems connected the actual LCD component to the controller card, as seen in step 9. We need more illustrations for actually connecting the ribbon cables (plural!) and for actually mounting the LCD and the controller card.
Tom Kane
Tom Kane - Ответить
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 47
За всё время: 5,366
