Canon EOS Rebel T5 Motherboard Replacement
Выберете то, что вам нужно
  1. Canon EOS Rebel T5 Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Motherboard Replacement, Back Panel: шаг 3, изображение 1 из 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
    2 more screws behind rubber cover.
    Michael Gill - Ответить
  4. Canon EOS Rebel T5 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
    There is a 6th screw next to the battery door.
  6. Canon EOS Rebel T5 Motherboard Replacement: шаг 6, изображение 1 из 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
    Instructions are forgetting the two screws on either side of the viewfinder…. Viewfinder slides up to reveal two screws.
    Hugh Morand - Ответить
  7. Canon EOS Rebel T5 Motherboard Replacement: шаг 7, изображение 1 из 3 Canon EOS Rebel T5 Motherboard Replacement: шаг 7, изображение 2 из 3 Canon EOS Rebel T5 Motherboard Replacement: шаг 7, изображение 3 из 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
    Do NOT pry until you’ve removed the eye gasket, and the 2 screws behind this! You will break the camera.
  8. Canon EOS Rebel T5 Motherboard Replacement, Motherboard: шаг 8, изображение 1 из 1
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
  9. Canon EOS Rebel T5 Motherboard Replacement: шаг 9, изображение 1 из 1
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm Phillips #000 screws.
  10. Canon EOS Rebel T5 Motherboard Replacement: шаг 10, изображение 1 из 3 Canon EOS Rebel T5 Motherboard Replacement: шаг 10, изображение 2 из 3 Canon EOS Rebel T5 Motherboard Replacement: шаг 10, изображение 3 из 3
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  11. Canon EOS Rebel T5 Motherboard Replacement: шаг 11, изображение 1 из 1
    • Remove the black 5 mm Phillips #000 screw, located under the grip.
    they is a cable i think gray in color on the top panel, where does it fit, it seems to come out easily
    Tshepiso Marques Molefe - Ответить
  12. Canon EOS Rebel T5 Motherboard Replacement: шаг 12, изображение 1 из 1
    • Remove the top panel of the device.
  13. Canon EOS Rebel T5 Motherboard Replacement: шаг 13, изображение 1 из 2 Canon EOS Rebel T5 Motherboard Replacement: шаг 13, изображение 2 из 2
    • Remove the front panel of the camera.
  14. Canon EOS Rebel T5 Motherboard Replacement: шаг 14, изображение 1 из 3 Canon EOS Rebel T5 Motherboard Replacement: шаг 14, изображение 2 из 3 Canon EOS Rebel T5 Motherboard Replacement: шаг 14, изображение 3 из 3
    • Remove the five silver 5mm Phillips #000 screws.
    • The motherboard can now be removed.
    Where can I buy a Motherboard for a T7 and what would the cost be?
    Dean Smith - Ответить
Заключение
9 участников успешно повторили данное руководство.
Austin Tucker
Участник с: 08/27/15
1 027 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 16-4, Wollert Fall 2015 Участник USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 членов
Автор 16 руководств
2 Комментариев
This guide is amazing, but if you change the mainboard do you have to initialize it by software, like Spt?
Edgar Nunes - Ответить
New main board from canon .
How to instalize?
Thomas Nguyen - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 27
За всё время: 4,148
