Canon EOS Rebel T6i LCD Display Replacement
Выберете то, что вам нужно
  1. Canon EOS Rebel T6i LCD Display Replacement, LCD Display: шаг 1, изображение 1 из 1
    • Remove the battery and use an anti-static wrist strap to ground yourself to prevent damage to device.
    • 2 screws on the side -1.3 mm
  2. Canon EOS Rebel T6i LCD Display Replacement: шаг 2, изображение 1 из 2 Canon EOS Rebel T6i LCD Display Replacement: шаг 2, изображение 2 из 2
    • 4 screws are located on the opposite/interior side of screen case. Use the J000 gauge screw driver head to remove these 4 screws. Furthermore, these screws are a larger gauge then the other 2. Please sort these accordingly.
    • 4 small screws on back 1.58 mm
  3. Canon EOS Rebel T6i LCD Display Replacement: шаг 3, изображение 1 из 2 Canon EOS Rebel T6i LCD Display Replacement: шаг 3, изображение 2 из 2
    • Following the removal of the 6 screws, Locate the joint of the casing. Place a flat lever inside this crevice and apply pressure. The case should simply pop open into the 2 casing pieces and the screen mechanism. Warning. No Dot try to remove bottom casing until next step.
  4. Canon EOS Rebel T6i LCD Display Replacement: шаг 4, изображение 1 из 3 Canon EOS Rebel T6i LCD Display Replacement: шаг 4, изображение 2 из 3 Canon EOS Rebel T6i LCD Display Replacement: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • There are several components inside the casing. A board, a power cable, the screen and a ribbon cable. First, using tweezers lift the metallic clamp connecting the ribbon to the board.
    • WARNING. If the lever doesn't lift immediately, do not forcefully lift it. This could damage the ribbon and board. When reapplying the ribbon, secure connection.
  5. Canon EOS Rebel T6i LCD Display Replacement: шаг 5, изображение 1 из 1
    • Now that the ribbon is disconnected, remove the board carefully and place it aside. This piece still works so leave it attached to camera.
  6. Canon EOS Rebel T6i LCD Display Replacement: шаг 6, изображение 1 из 2 Canon EOS Rebel T6i LCD Display Replacement: шаг 6, изображение 2 из 2
    • The screen is glued into the casing. Remove the screen by carefulyl lifting along the edges of the case until the screen pops out. Place new screen into the existing casing. A small about of glue or adhesive may be necessary if their isn't sufficient adhesive remaining in the case. Repeat steps in reverse to reapply screen.
  7. Canon EOS Rebel T6i LCD Display Replacement: шаг 7, изображение 1 из 1
    • If screen doesn't power on after replacing the battery, Go back and check connections of the ribbon.
Заключение
Еще один человек закончил это руководство.
Shane Riding
Участник с: 03/21/18
861 Репутация
Автор 4 руководств
Команду
University of Memphis, Team S2-G1, Kim Spring 2018 Участник University of Memphis, Team S2-G1, Kim Spring 2018
UM-KIM-S18S2G1
3 членов
Автор 11 руководств
3Комментарии к руководству
Very simple and great guide for. See the Canon T6i Bundle
Deve Lee - Ответить
Thanks for this awesome guide its really useful for me. see the Canon 80D Bundle
9 Product Reviews - Ответить
y las refacciones donde?
cafeplazay - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 12
За последние 30 дней: 77
За всё время: 4,390
