Введение
This guide will show how to get to and replace the motherboard.
Выберете то, что вам нужно
Remove two 6.8 mm JIS #000 screws on the right side.
Remove six 5.3 mm JIS #000 screws on the bottom.
Remove two 5.3 mm JIS #000 screws on either side of the viewfinder.
Remove one 5.9 mm JIS #000 screw on the top right.
Remove one 3.4 mm JIS #000 screw on the top left.
Using a metal spudger, pry the rubber grip off of the casing on the left side of the camera.
Remove five silver 5.8 mm JIS #000 screws from underneath the grip.
Carefully use the plastic opening tool to pry the casing apart along the seam.
Follow the seam with the plastic tool until the back is ready to remove.
To disconnect the white wire, pinch the wire casing and pull it directly out from the camera.
To disconnect the ribbon connector, softly pull the back away from the motherboard. It should come undone with little force.
Once removed, set the back in a safe place.
Remove the five ribbon connectors along the bottom of the assembly using either needle nose tweezers or a plastic opening tool to flip the small flaps to the "up" position.
Use a nylon spudger to pull each ribbon connector out of its connection using the hole in the center of the ribbon.
Disconnect the small plastic connectors on the top left corner of the motherboard by gripping the small plastic portion of the wire and gently pulling out of the connector.
Disconnect the three ribbon connectors along the top.
Remove the four screws from the front of the camera. There are two screws above the lens mount and two screws inside the lens mount.
Remove the four screws from the bottom of the camera.
Remove the yellow and red connections on the front near the black cylinder (capacitor).
The yellow connector will just pop out if pried from the bottom using a plastic opening tool.
The red connector will pull out of the casing with either a plastic opening tool or a thin set of tweezers.
Remove the diopter adjustment knob next to the viewfinder using a JIS #000 screwdriver.
Remove the entire upper flash assembly by gently pulling it up and off the camera.
Disconnect the ribbon connector on the upper right side of the motherboard.
Pull back the foam on the connector on the far right side of the motherboard.
Flip up the tab on the connector and remove the cable.
Remove the two screws on the right side of the motherboard as well as the screw in the center.
Remove the two screws connecting the metal port bracket to the motherboard.
Slide the metal bracket out of the camera.
7 участников успешно повторили данное руководство.
2 Комментариев
Good tutorial! Two things I noticed on my teardown, on step 6 the white grounding wire has two black tabs on either side you can lift with a guitar pick, much better than pulling on the wire casing; on step 12 the picture is misleading as you pull the plug out towards the middle of the body. Those are very minor things, this was an extremely helpful tutorial! Not for the faint of heart aha
