Canon EOS Rebel XS 35mm Bottom Cover and More Replacement
Выберете то, что вам нужно
  1. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover: шаг 1, изображение 1 из 1
    • Remove 6 screws using a PH000 Screwdriver.
    • Remove 1 (7mm) screw
    • Remove 5 (4mm) screws
  2. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 2, изображение 1 из 1
    • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 3, изображение 1 из 1
    • With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
  4. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover and More: шаг 4, изображение 1 из 1
    • Remove the 5mm silver Phillips #000 screw.
    • Remove three 4mm Phillips #000 screws.
  5. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 5, изображение 1 из 1
    • Remove the silver plate with tweezers or fingers.
  6. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 6, изображение 1 из 1
    • Be mindful of the spring attached to the plastic piece. Do not lose it.
    • Remove the plastic black part.
  7. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 7, изображение 1 из 1
    • Remove the black gear with tweezers or fingers.
  8. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 8, изображение 1 из 1
    • Remove the gear with tweezers or fingers.
  9. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 9, изображение 1 из 1
    • Remove the part indicated in the picture with tweezers or fingers.
  10. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 10, изображение 1 из 1
  11. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 11, изображение 1 из 1
  12. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 12, изображение 1 из 2 Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 12, изображение 2 из 2
    • Remove two 3mm Phillips #000 screws.
    • Remove two silver 3.5mm Phillips #000 screws.
  13. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: шаг 13, изображение 1 из 1
    • Remove the second silver plate using tweezers or fingers.
Заключение
christiansvezia
Участник с: 10/24/18
1 108 Репутация
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 19
За всё время: 336
