Введение
Use this guide to replace the grip of the camera.
Запчасти
Никакие детали не требуются.
  1. Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
      • There's a concealed lip, under the opposite edge.
    • Remove three medium length screws from the bottom of the camera
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
    • Use your fingertip to pry off the external shutter port cover.
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
    • Once the grip is loose, use your fingers to remove it from the camera.
Заключение
Daniel Bussone
Участник с: 28.01.2011
1 239 Репутация
Автор 11 руководств
Команда
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 членов
Автор 11 руководств
Один комментарий
Little confused. Some pics are from a analog Canon, other from a digital Canon...
Gustavo Aguiar - Ответить
Просмотр статистики:
За 24 часа: 1
За 7 дней: 2
За 30 дней: 8
За всё время: 3,072
