Введение
Use this guide to replace the grip of the camera.
Выберете то, что вам нужно
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
Pry up the panel; starting from the front/bottom corner, as indicated.
There's a concealed lip, under the opposite edge.
Remove three medium length screws from the bottom of the camera
Remove the two medium length screws on the front panel of the camera above the lens mount.
Once you done, you may use the Spudger to panel from non-grip side.
Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
Еще один человек закончил это руководство.
Один комментарий
Little confused. Some pics are from a analog Canon, other from a digital Canon...
