Canon EOS Rebel XS Lens Mount Ring Replacement
Выберете то, что вам нужно
  1. Canon EOS Rebel XS Lens Mount Ring Replacement, Latch Side Cover: шаг 1, изображение 1 из 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS Lens Mount Ring Replacement: шаг 2, изображение 1 из 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS Lens Mount Ring Replacement, Disassembling Canon EOS Rebel XS Front Cover: шаг 3, изображение 1 из 1
    • Remove three medium length screws from the bottom of the camera
  4. Canon EOS Rebel XS Lens Mount Ring Replacement: шаг 4, изображение 1 из 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Canon EOS Rebel XS Lens Mount Ring Replacement, Canon EOS Rebel XS Lens Mount Ring Replacement: шаг 5, изображение 1 из 1
    • Remove the five silver screws from the lens mounting ring using a Phillips screwdriver.
  6. Canon EOS Rebel XS Lens Mount Ring Replacement: шаг 6, изображение 1 из 1
    • Use your fingers to remove the lens mounting ring.
    • There is a small metal button housed in the ring (red square). Be careful not to lose this piece when removing the ring.
  7. Canon EOS Rebel XS Lens Mount Ring Replacement: шаг 7, изображение 1 из 1
    • Use a pair of tweezers to remove the spring on the lens mounting ring.
  8. Canon EOS Rebel XS Lens Mount Ring Replacement: шаг 8, изображение 1 из 1
    • Use a pair of tweezers to remove the gold metal ring.
    • Take note of the ring's orientation for re-installing it.
Заключение
3 участников успешно повторили данное руководство.
Daniel Bussone
Участник с: 01/28/11
1 251 Репутация
Автор 11 руководств
Команда
Cal Poly, Team 3-41, Regan Winter 2011 Участник Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 членов
Автор 21 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 7,600
