Введение
This replacement guide shows how to remove this device's back panel. This step is necessary to replace many internal components of the camera.
Выберете то, что вам нужно
Squeeze the eyepiece between your index finger and thumb and lift up and off.
Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
3 участников успешно повторили данное руководство.
