Введение
This replacement guide shows how to remove the device's daughter board, also known as the mother board extension located on the front side of the camera. The front panel must be removed before hand.
Запчасти
No parts specified.
  1. Squeeze the eyepiece between your index finger and thumb and lift up and off
    • Squeeze the eyepiece between your index finger and thumb and lift up and off
  2. Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera
  3. On the right side of the camera (from the LCD screen), use the PH000 screwdriver head to remove the two 3mm screws
    • On the right side of the camera (from the LCD screen), use the PH000 screwdriver head to remove the two 3mm screws
  4. Remove grip by slowly peeling off
    • Remove grip by slowly peeling off
  5. Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece
  6. On the left side of the camera (from the LCD screen), use the PH000 screwdriver head to remove one 4 mm screw
    • On the left side of the camera (from the LCD screen), use the PH000 screwdriver head to remove one 4 mm screw
  7. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  8. Remove side panel by lifting off with fingers
    • Remove side panel by lifting off with fingers
  9. Use hands to pry off the back panel
    • Use hands to pry off the back panel
  10. Using the PH000 screwdriver head, remove the four 3mm screws on the front
    • Using the PH000 screwdriver head, remove the four 3mm screws on the front
  11. Remove front grip by gently peeling from the edge towards the center of the camera
    • Remove front grip by gently peeling from the edge towards the center of the camera
  12. Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
    • Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
  13. Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
    • Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
  14. Remove the front panel by using tweezers to pry the panel over the metal ring protrusion Remove the front panel by using tweezers to pry the panel over the metal ring protrusion Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
    • Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
  15. Using the PH000 screwdriver head, remove the three 3mm screws
    • Using the PH000 screwdriver head, remove the three 3mm screws
  16. Carefully remove the cable from its plastic base with fingers
    • Carefully remove the cable from its plastic base with fingers
  17. Gently slide board out with thumb
    • Gently slide board out with thumb
  18. Gently disconnect cable by pulling out from plastic base with fingers
    • Gently disconnect cable by pulling out from plastic base with fingers
  19. Disconnect cables by pulling out from base with fingers
    • Disconnect cables by pulling out from base with fingers
Заключение
2 участников успешно повторили данное руководство.
Erik Mork
Участник с: 27.01.2017
557 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 22-10, Maness Winter 2017 Member of Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 членов
Автор 5 руководств
Один комментарий
what does this fix
djratlif - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 10
За всё время: 565
