Введение
This replacement guide shows how to remove the device's front panel. This is necessary to access internal components that are located in the front.
Выберете то, что вам нужно
Squeeze the eyepiece between your index finger and thumb and lift up and off.
Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
Using the PH000 screwdriver head, remove the four 3mm screws on the front
Remove front grip by gently peeling from the edge towards the center of the camera
Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
2 участников успешно повторили данное руководство.
