Введение
This replacement guide shows how to remove the camera's LCD screen. The back panel must be removed before hand.
Выберете то, что вам нужно
Squeeze the eyepiece between your index finger and thumb and lift up and off.
Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
Using the PH00 screwdriver head, unscrew four 4 mm screws and one 2 mm screw
Using the plastic spudger, carefully pry out the LCD screen from the back panel
