Canon EOS Rebel XTi Snapshot Button Replacement
Выберете то, что вам нужно
  1. Canon EOS Rebel XTi Snapshot Button Replacement, Battery: шаг 1, изображение 1 из 1
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Canon EOS Rebel XTi Snapshot Button Replacement: шаг 2, изображение 1 из 1
    • Pull the orange tab to the right to release the primary battery.
  3. Canon EOS Rebel XTi Snapshot Button Replacement: шаг 3, изображение 1 из 1
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
  4. Canon EOS Rebel XTi Snapshot Button Replacement, Memory Card: шаг 4, изображение 1 из 1
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Canon EOS Rebel XTi Snapshot Button Replacement: шаг 5, изображение 1 из 1
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Canon EOS Rebel XTi Snapshot Button Replacement: шаг 6, изображение 1 из 1
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  7. Canon EOS Rebel XTi Snapshot Button Replacement, Top Casing: шаг 7, изображение 1 из 3 Canon EOS Rebel XTi Snapshot Button Replacement, Top Casing: шаг 7, изображение 2 из 3 Canon EOS Rebel XTi Snapshot Button Replacement, Top Casing: шаг 7, изображение 3 из 3
    • Remove the single 10 mm JIS #00 shoulder screw.
    • Remove the two 6 mm JIS #00 screws.
  8. Canon EOS Rebel XTi Snapshot Button Replacement: шаг 8, изображение 1 из 1
    • Separate the top casing from the electrical components enough to expose the wire harnesses that will need to be disconnected.
    • Ensure to remove the casing gently. There are several wire harnesses connecting the motherboard to components on the casing.
  9. Canon EOS Rebel XTi Snapshot Button Replacement: шаг 9, изображение 1 из 1
    • Unplug the yellow connector located on the top of the camera.
  10. Canon EOS Rebel XTi Snapshot Button Replacement: шаг 10, изображение 1 из 1
    • Disconnect the red connector located by the USB port.
  11. Canon EOS Rebel XTi Snapshot Button Replacement, Snapshot Button: шаг 11, изображение 1 из 1
    • Use a J00 screwdriver to remove the two silver 4 mm screws from underneath the snapshot button.
  12. Canon EOS Rebel XTi Snapshot Button Replacement: шаг 12, изображение 1 из 3 Canon EOS Rebel XTi Snapshot Button Replacement: шаг 12, изображение 2 из 3 Canon EOS Rebel XTi Snapshot Button Replacement: шаг 12, изображение 3 из 3
    • Use a J00 screwdriver to remove the 3 mm screws from the plate under snapshot the snapshot button.
    • Place the components off to the side without removing any ribbons.
    • Be careful as ribbon cables are fragile and may rip easily.
  13. Canon EOS Rebel XTi Snapshot Button Replacement: шаг 13, изображение 1 из 1
    • Use a 1.5 flat head bit to remove the c-clip from underneath the snapshot button by pushing against the open side of the pin.
Заключение
Luis Calle
Участник с: 08/30/15
416 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 8-6, Eyestone Fall 2015 Участник USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 членов
Автор 18 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 1,041
