Введение
If your camcorder LCD screen is scratched, cracked or defective in any way, it will have to be replaced. This guide requires some tools and time.
Выберете то, что вам нужно
Locate battery compartment cover. Turn the device over and locate the battery compartment cover.
Place a finger or thumb on the textured section of the battery compartment cover and push forward until you hear a click. Then lift the battery compartment cover.
Locate the grey latch and move it aside. The battery is spring loaded and will pop up.
Remove the battery.
Using the Phillips #000, remove the two screws on the LCD panel.
Using the Phillips #000, remove two more screws near the LCD panel swivel point.
Locate and remove two screws on the logic board.
Use the plastic opening tool to open the ZIF (zero insertion force) connector. The LCD ribbon should pop up.
Еще один человек закончил это руководство.
