Введение
This guide will teach you how to replace a faulty speaker.
Выберете то, что вам нужно
Lift the printer lid up as shown in the photo.
Unhook the plastic panel from the printer starting from the top.
To remove the bottom part of the paneling gently lay the printer on its back.
Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
Locate the black 7mm screw holding the speaker in place.
Using a Phillips head screw driver, unscrew the 7mm screw.
Locate the red and black wires connected to the speaker.
Undo the white clip holding the wires in place by pinching the tab on the top.
Remove the red and black wires from the wire bundle.
Lift out the speaker
Еще один человек закончил это руководство.
