Введение
If your printed documents or images are becoming distorted due to a dysfunctional printhead, use this guide to replace the printhead.
Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
Push in the white clip to release the ink cartridge from the printhead.
Lift the ink cartridge from the printhead.
Repeat this process for the remaining ink cartridges.
You have successfully removed all ink cartridges.
Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
5 участников успешно повторили данное руководство.
