Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Place thumb on area right next to where it says open and slide to the right to open.
Remove the battery by pushing the orange object outwards; the battery will spring up and out.
Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
Place the camera on to the side that has the image stabilizer label.
Remove the 5.00 mm screws that are on this side using the screwdriver.
Place camera on to the side with the A/V Out Digital Cover facing up.
Remove this visible 5.00 mm screw.
Pull the A/V Out Digital cover back to uncover the next step.
Turn the camera onto the side with the A/V out Digital cover.
Use your finger to pull this tab to the right.
Remove the lens side by using your fingers or a spudger to pry it gently open.
Еще один человек закончил это руководство.
