Введение
Replacement of the lens usually needs to take place when the lens no longer retracts or when the lens has been damaged due to scratches or cracks. This scenario is usually accompanied by the common E18 error showing up on the LCD display.
Запчасти
No parts specified.
  1. Place thumb on area right next to where it says open and slide to the right to open.
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Remove the battery by pushing the orange object outwards; the battery will spring up and out.
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Place the camera on to the side that has the image stabilizer label. Remove the 5.00 mm screws that are on this side using the screwdriver.
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Place camera on to the side with the A/V Out Digital Cover facing up.
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  7. Remove the 5.00 mm screw from behind the cover.
    • Remove the 5.00 mm screw from behind the cover.
  8. Make sure the battery cover is open.
    • Make sure the battery cover is open.
  9. Turn the camera onto the side with the A/V out Digital cover. Use your finger to pull this tab to the right.
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  10. Remove the lens side by using your fingers or a spudger to pry it gently open. Try to pry it loose all around that side so that it is easier to pull off. Try to pry it loose all around that side so that it is easier to pull off.
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  11. Using your fingers, pull the screen side gently off. Try to loosen it all around that side so that it is easier to try and pull it off. Try to loosen it all around that side so that it is easier to try and pull it off.
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
  12. Remove the three 5 mm screws Remove the three 5 mm screws Remove the three 5 mm screws
    • Remove the three 5 mm screws
  13. Pull the screen away from the main components. Do not pull hard as there are some ribbons still attached to the motherboard that could be damaged if you use too much force. Do not pull hard as there are some ribbons still attached to the motherboard that could be damaged if you use too much force.
    • Pull the screen away from the main components.
    • Do not pull hard as there are some ribbons still attached to the motherboard that could be damaged if you use too much force.
  14. Lift the metal plate with the plastic opening tool. Lift the metal plate with the plastic opening tool.
    • Lift the metal plate with the plastic opening tool.
  15. Remove all of these 5 mm screws
    • Remove all of these 5 mm screws
  16. Gently remove the lens componenet. The orange flex cables are connected to ZIF connectors. Be sure to disconnect and reconnect them properly by first unlocking the retaining flap on each connector. The orange flex cables are connected to ZIF connectors. Be sure to disconnect and reconnect them properly by first unlocking the retaining flap on each connector.
    • Gently remove the lens componenet.
    • The orange flex cables are connected to ZIF connectors. Be sure to disconnect and reconnect them properly by first unlocking the retaining flap on each connector.
Заключение
tariq
Участник с: 13.01.2015
131 Репутация
1 Guide authored
Команда
USF Tampa, Team 1-1, Sullivan Winter 2015 Member of USF Tampa, Team 1-1, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G1
3 членов
Автор 4 руководств
Комментариев: 2
SOOOO! How do you plug those oranges wires back?? Ive been wasting my time trying to plug it but i have no clue how.. It's too short and its hard to secure it..
The Heat - Ответить
I don’t own this camera but that does look like an oversight in this guide. Those are flex cables secured by ZIF connectors and it’s not enough to just “pull them slowly” as originally stated in this guide. I’ve tried to update the instructions accordingly, but some additional pictures would be helpful.
Jeff Suovanen -
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 7
За всё время: 463
