Введение
This guide is important since it will allow you to access the internal components of the camera. It will also allow you to replace the plastic case if the case has been damaged or warped in any fashion.
Выберете то, что вам нужно
Place thumb on area right next to where it says open and slide to the right to open.
Remove the battery by pushing the orange object outwards; the battery will spring up and out.
Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
Place the camera on to the side that has the image stabilizer label.
Remove the 5.00 mm screws that are on this side using the screwdriver.
Place camera on to the side with the A/V Out Digital Cover facing up.
Remove this visible 5.00 mm screw.
Pull the A/V Out Digital cover back to uncover the next step.
Turn the camera onto the side with the A/V out Digital cover.
Use your finger to pull this tab to the right.
Еще один человек закончил это руководство.
