Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Involving removal of the camera casing as well, this guide will help the user remove the LCD screen to repair or replace it.
Выберете то, что вам нужно
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
Remove the second battery cover on the bottom of camera.
Take the silver battery out of the camera.
Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
Remove the light grey, plastic piece.
Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
Slightly pull on each side of the camera. It should loosen up and come apart.
If it does not pull apart right away, use a little more force.
Do not give up!
Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
3 участников успешно повторили данное руководство.
2 Комментариев
Explained in detail, very clear, easy to understand. I just unpacked it for the first time. Still able to do as told. Thank you.
