Выберете то, что вам нужно
Turn off the camera.
Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
Turn the camera upside down to view the "Card/Batt. Open" Cover.
Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
Open "Card/Batt. Open" Cover.
Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
Turn the camera to the right side of the LCD screen.
Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
Gently remove the back cover.
Start at the bottom at the corner of the "Card/Batt. Open" Cover.
Then move onto the other edges and the top.
2 участников успешно повторили данное руководство.
Один комментарий
Mon écran arrière es craque et ne fonctionne plus mais le reste fonctionne très bien,
ma question es ou je peut me procurer un écran PowerShot A540
jmucienko@sympatico.ca
