Введение
If your camera will not flash correctly, even with the proper settings, you might need to replace the flash motherboard. After removing the front and back covers, as well as the LCD screen, you will be able to replace the flash motherboard yourself.
Выберете то, что вам нужно
Turn off the camera.
Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
Turn the camera upside down to view the "Card/Batt. Open" Cover.
Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
Open "Card/Batt. Open" Cover.
Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
Turn the camera to the right side of the LCD screen.
Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
Gently remove the back cover.
Start at the bottom at the corner of the "Card/Batt. Open" Cover.
Then move onto the other edges and the top.
Turn the camera to view the front.
Remove the lens guard.
Press the lens guard's button as you turn the guard counterclockwise.
Turn the camera to the side left of the LCD screen.
Remove the one (1) 4.0 mm screw with the Phillips head #000 screwdriver.
Turn camera so that you see the top side with the settings wheel.
Use a Phillips head #000 screwdriver to remove the one (1) 5.0 mm screw at the top as shown.
Using a soldering iron and a desoldering wick, carefully disconnect all the wires from where they come into contact with the flash motherboard.
When all the wires are disconnected, you are ready to replace the flash motherboard.
