Введение
Use this guide to replace the Canon PowerShot A75's batteries.
  1. Turn the camera over and locate the "BATT OPEN" sliding switch.
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  3. Slide the switch to the right. The battery cover should slide down and spring open. The battery cover should slide down and spring open.
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  4. Remove the 4 AA batteries. Watch for the orientation of the batteries as they slide out. The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
Заключение
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Команда
Cal Poly, Team 17-30, Amido Spring 2012 Member of Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 членов
Автор 6 руководств
Комментариев: 2
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - Ответить
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 3
За всё время: 706
