Введение
Use this guide to replace the Canon Powershot A75's casing.
Выберете то, что вам нужно
Open the memory card slot by sliding it laterally until you hear a click.
Remove the 5.9mm screw in the upper corner of the memory card slot.
Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
On the front of the camera, press the button on the lower left of the lens.
Twist the outer lens casing counter-clockwise and slide it out.
4 участников успешно повторили данное руководство.
