Введение
Use this guide to replace the Canon Powershot A75's speaker unit.
Выберете то, что вам нужно
Open the memory card slot by sliding it laterally until you hear a click
Remove the 5.9mm screw in the upper corner of the memory card slot
Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
