Введение
Having trouble seeing images on the LCD Screen on the back of your Canon PowerShot A80 making it hard to focus on the scene you are trying to photograph?
Follow this guide to learn how to remove and replace the LCD Screen so you can get back to capturing those precious moments.
Выберете то, что вам нужно
Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
Using a Phillips #00 screwdriver, remove the 2.9 mm screws on the other side of the screen to separate the front and back covers.
Gently remove the front and back covers from the screen.
Peel back the plastic circuit cover.
4 участников успешно повторили данное руководство.
