Введение
This guide will help users of all abilities to replace the faceplate/front panel of their camera.
Выберете то, что вам нужно
Locate the ON/Off button on the top of the camera and hold it down until the screen and all lights on the camera go dark.
To remove the back plate you will need to unscrew the 6 support screws securing it to the camera.
Use a Phillips #00 screwdriver to remove the first 2 screws on the bottom of the camera.
Remove the next 2 screws located behind the AV port using the same Phillips #00 screwdriver.
Use a Phillips #00 screwdriver to remove the final 2 screws from the blue side panel.
Use your hands or a spudger to gently pry the front and back case apart along the seams on the bottom of the camera.
Completely remove the back plate.
