Canon PowerShot ELPH 300HS Back Panel Button Replacement
Выберете то, что вам нужно
    • Before you begin taking apart your device, the first, and MOST IMPORTANT STEPS are to:
    • Turn off your camera.
    • Remove the battery to prevent risk of shock.
  1. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Battery: шаг 2, изображение 1 из 2 Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Battery: шаг 2, изображение 2 из 2
    • Turn off your camera by pressing the power button, located on the top-center of the device.
    • Locate the battery door on the bottom right area of the camera case.
    • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
    • Locate the orange battery release button beneath the battery door.
    • Slide the battery release button downward to release the battery.
  2. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Left Side Screws: шаг 3, изображение 1 из 1
    • Be careful when removing screws, as they are stripped easily.
    • Remove the two screws located on the left side of the camera case, using the Phillips screwdriver #00 (2.0 mm).
  3. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Bottom Screws: шаг 4, изображение 1 из 1
    • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (4.0 mm).
  4. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Right Side Screws: шаг 5, изображение 1 из 1
    • Remove the screw located on the lower right side of the camera case (Phillips #00 screwdriver) (4.0 mm).
    • Remove the HDMI A/V out port cover located on the upper right side of the camera.
    • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
  5. Canon PowerShot ELPH 300HS Back Panel Button Replacement: шаг 6, изображение 1 из 1
    • Remove the back portion of the camera case to reveal the screw located on the top of the case.
    • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (1.5 mm).
  6. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Case from the Camera: шаг 7, изображение 1 из 3 Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Case from the Camera: шаг 7, изображение 2 из 3 Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove the Case from the Camera: шаг 7, изображение 3 из 3
    • Carefully pry the case apart at the seem, using your fingers.
    • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
    • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
  7. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Remove & Replace: шаг 8, изображение 1 из 1
    • Now that you have followed the steps to remove the case, you can remove the back panel of your camera and replace it with your new panel.
  8. Canon PowerShot ELPH 300HS Back Panel Button Replacement, Reassemble: шаг 9, изображение 1 из 1
    • Now that you have replaced your back panel buttons, you can reassemble the device in reverse order of the instructions in the Camera Case Replacement guide.
Заключение
Еще один человек закончил это руководство.
Kristin Brusso
Участник с: 02/24/14
175 Репутация
1 руководство автора
Команда
Michigan Tech, Team 5-6, Lauer Spring 2014 Участник Michigan Tech, Team 5-6, Lauer Spring 2014
MTU-LAUER-S14S5G6
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 688
