Canon PowerShot ELPH 300HS Flash Replacement
Выберете то, что вам нужно
    • Before you begin taking apart your device, the first, and MOST IMPORTANT STEPS are to:
    • Turn off your camera.
    • Remove the battery to prevent risk of shock.
  1. Canon PowerShot ELPH 300HS Flash Replacement, Remove the Battery: шаг 2, изображение 1 из 2 Canon PowerShot ELPH 300HS Flash Replacement, Remove the Battery: шаг 2, изображение 2 из 2
    • Turn off your camera by pressing the power button, located on the top-center of the device.
    • Locate the battery door on the bottom right area of the camera case.
    • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
    • Locate the orange battery release button beneath the battery door.
    • Slide the battery release button downward to release the battery.
  2. Canon PowerShot ELPH 300HS Flash Replacement, Left Side Screws: шаг 3, изображение 1 из 1
    • Be careful when removing screws, as they are stripped easily.
    • Remove the two screws located on the left side of the camera case, using the Phillips screwdriver #00 (2.0 mm).
  3. Canon PowerShot ELPH 300HS Flash Replacement, Bottom Screws: шаг 4, изображение 1 из 1
    • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (4.0 mm).
  4. Canon PowerShot ELPH 300HS Flash Replacement, Right Side Screws: шаг 5, изображение 1 из 1
    • Remove the screw located on the lower right side of the camera case (Phillips #00 screwdriver) (4.0 mm).
    • Remove the HDMI A/V out port cover located on the upper right side of the camera.
    • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
  5. Canon PowerShot ELPH 300HS Flash Replacement: шаг 6, изображение 1 из 1
    • Remove the back portion of the camera case to reveal the screw located on the top of the case.
    • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (1.5 mm).
  6. Canon PowerShot ELPH 300HS Flash Replacement, Remove the Case from the Camera: шаг 7, изображение 1 из 3 Canon PowerShot ELPH 300HS Flash Replacement, Remove the Case from the Camera: шаг 7, изображение 2 из 3 Canon PowerShot ELPH 300HS Flash Replacement, Remove the Case from the Camera: шаг 7, изображение 3 из 3
    • Carefully pry the case apart at the seem, using your fingers.
    • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
    • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
  7. Canon PowerShot ELPH 300HS Flash Replacement, LCD Screen: шаг 8, изображение 1 из 2 Canon PowerShot ELPH 300HS Flash Replacement, LCD Screen: шаг 8, изображение 2 из 2
    • Disconnect the copper ribbon next to the blue port on the motherboard
    • To remove ribbon cable, gently lift the black tab with a flat head screwdriver. Lift from the top of the camera towards the bottom. This releases the cable. Be gentle, as the cables are fragile.
  8. Canon PowerShot ELPH 300HS Flash Replacement: шаг 10, изображение 1 из 3 Canon PowerShot ELPH 300HS Flash Replacement: шаг 10, изображение 2 из 3 Canon PowerShot ELPH 300HS Flash Replacement: шаг 10, изображение 3 из 3
    • Remove the L shaped bracket around the top and right side of the LCD screen
  9. Canon PowerShot ELPH 300HS Flash Replacement: шаг 11, изображение 1 из 3 Canon PowerShot ELPH 300HS Flash Replacement: шаг 11, изображение 2 из 3 Canon PowerShot ELPH 300HS Flash Replacement: шаг 11, изображение 3 из 3
    • Insert the flat side of the spudger tool carefully on the top of the LCD screen and lift the screen free
  10. Canon PowerShot ELPH 300HS Flash Replacement, Flash: шаг 12, изображение 1 из 2 Canon PowerShot ELPH 300HS Flash Replacement, Flash: шаг 12, изображение 2 из 2
    • Carefully remove the large copper ribbon on the front of the camera (attached with adhesive pads)
  11. Canon PowerShot ELPH 300HS Flash Replacement: шаг 13, изображение 1 из 2 Canon PowerShot ELPH 300HS Flash Replacement: шаг 13, изображение 2 из 2
    • Remove the ribbon wire attached at the bottom right corner of the front of the camera. You do NOT need to remove this from the motherboard.
  12. Canon PowerShot ELPH 300HS Flash Replacement: шаг 14, изображение 1 из 3 Canon PowerShot ELPH 300HS Flash Replacement: шаг 14, изображение 2 из 3 Canon PowerShot ELPH 300HS Flash Replacement: шаг 14, изображение 3 из 3
    • Unscrew the screw on the circuit board on the front of the camera (length 3.5 mm)
    • Unscrew the screw on the lower left part of the silver part of the back under where the LCD screen was.
    • Unscrew the screw on the top of the silver part of the back
  13. Canon PowerShot ELPH 300HS Flash Replacement: шаг 15, изображение 1 из 3 Canon PowerShot ELPH 300HS Flash Replacement: шаг 15, изображение 2 из 3 Canon PowerShot ELPH 300HS Flash Replacement: шаг 15, изображение 3 из 3
    • Lift the flash housing up and forward from the top of the camera to carefully remove
Заключение
Еще один человек закончил это руководство.
Kathryn Van Susante
Участник с: 02/26/14
667 Репутация
Автор 5 руководств
Команда
Michigan Tech, Team 5-6, Lauer Spring 2014 Участник Michigan Tech, Team 5-6, Lauer Spring 2014
MTU-LAUER-S14S5G6
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 1,034
