Введение
The Canon PowerShot ELPH 310 HS may experience some damage to the outer casings. If you need to remove the outer casings to replace another component, or need to replace the outer casing, follow this guide.
Выберете то, что вам нужно
Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
Using your hands, remove the image stabilizer panel.
Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
Unscrew the hidden 4mm Phillips head screw inside the battery portal.
Remove the HDMI side panel with your hands.
Unscrew the four 4 mm Phillips head screws from the inside of the camera.
Один комментарий
I have lost the two 4mm screws from the bottom of the camera and would like to buy replacements. Does anyone know the exact size of these screws?
