Введение
The Cannon PowerShot ELPH 310 HS may experience problems with the lens. The lens may be stuck inside the camera, or will not retract back into the camera. This guide is to assist in the replacement of the lens.
Выберете то, что вам нужно
Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
Using your hands, remove the image stabilizer panel.
Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
Unscrew the hidden 4mm Phillips head screw inside the battery portal.
Remove the HDMI side panel with your hands.
Unscrew the four 4 mm Phillips head screws from the inside of the camera.
Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
On the front motherboard, unscrew the one bottom right 3 mm Phillips head screw.
Unscrew the four 3 mm Phillips head screws attached to the metal casing on the back of the camera, behind where the LCD screen once was.
Using your hands, carefully lift the flash housing up and remove it from the area.
Using your hands, carefully remove the center ribbon.
Manually remove the lens.
4 участников успешно повторили данное руководство.
Один комментарий
excellent procedure. nice pix too. hint about those fragile flex cables is important, they are thinner than a human hair!
